by Bartekkp
Cant call abroad
Hello,
I have problems with calling abroad. When im trying it says "YouTube cannot do International calls from this number"
Re: Cant call abroad
You need to call EE to lift the International calling bar.
by Brilliant Contributor
Hello @Bartekkp,
Welcome to the community,
Have you made sure that Roaming is enabled on your account? You may have to ring customer service to get this enabled.
I presume you are trying to call abroad from the UK?
You can also check in your account and see if roaming is enabled, but probably will still need to ring customer service to enable this.
@Schockwave: I don't think OP is roaming, just trying to make International calls from UK. Hence the error msg.
EE Employee
Welcome to the community @Bartekkp
As advised if you give customer services a call they'll be able to lift the international bar for you.
Let us know if you need anything else.
Thanks - Karen. Smiley Happy
