by Dingdalling1973
New Member
Cannot use phone in Spain to call, told it is locked
Re: Cannot use phone in Spain to call, told it is locked
Hi @Dingdalling1973
If you log into your account then menu - manage your device. Ensure roaming and international calls are activated.
Hi @Dingdalling1973
Welcome to the community, I hope you're having a brilliant time in Spain so far. 😄
If your roaming and international calling are set up in your My EE account, and you're still having problems, I recommend searching for an available network manually.
Device type Actions
iPhone Settings > Mobile Data > Network Selection > Turn off Automatic
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Let us know how you're getting on.
Recent solutions
