by emmadav
Cannot send texts or make calls abroad, can use data
I’ve arrived in France and got a text from EE to acknowledge this. I have a pay as you go sim and can use my data here but cannot make calls or send texts, I have tried restarting my phone a couple of times which has not worked. How can I fix this?
Re: Cannot send texts or make calls abroad, can use data
Hi @emmadav
Make sure roaming is activated under your phone network settings.
Also make sure you add +44 if calling the UK.
You don't need to activate any additional services on PAYG other than ensuring you have enough credit.
Hello there @emmadav
Welcome to the community.
If the steps from @Northerner have not got you up and running.
Can you try and select a manual network from your phone settings as below;
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Thanks, Leanne.
