by Nicky_P
Cannot roam with TP-Link M7350
Hi everyone, hope someone can help me
i have bought a TP-Link M7350 to use in Spain with my Ipad as it has no SIM card slot.
i have a 4G EE sim that works fine in a phone and I can tether to the sim when it is in a phone.
although the TP-Link says it's connected to Orange and my PC shows I have connected to the ttplink, I still cannot open a web page.
does anyone know if there is anything else I need to do to access wifi through the Tplink?
by Profile closed
Not applicable
Solution
Re: Cannot roam with TP-Link M7350
Hello @Nicky_P you can log in to check the routers settings by accessing this link when connected to it. Default username and password are admin/admin:
http://192.168.0.1
Have you got the correct EE APN settings:
APN: everywhere
Username: eesecure
Password: secure
11 REPLIES 11
by Profile closed
Not applicable
Solution
http://192.168.0.1
APN: everywhere
Username: eesecure
Password: secure
Hi @Nicky_P
Thank you for coming to see us in community 🙂
Have you by any chance added a data roaming bundle to the account?
Just open your browser when you're abroad and go to add-on.ee.co.uk.
You will do this in order to access the internet.
Richard
by Rudihorvath Contributor
Hi Tom222
Many thanks for your help. It looks like the APN settings were stoping me from connecting.
After some trial and error I finally managed to dial in with the Tplink.
I followed your instructions and after going to 192.168.0.1 then clicked "advanced" and created a new dial up setting with the APN details you suggested.
After saving and confirming that I wanted to connect with the newly created dial-up the status under "wireless" has now changed to connected.
i am now able to use the date on both my iPad and my Pc.
Many thanks again.
Nicky
Hi Richard
its all working now thanks.
i had plenty of roaming data on the sim, 15g per month, but I had to change the APN settings.
See my prev reply.
thanks
Nicky
by Profile closed
Not applicable
You are welcome @Rudihorvath glad to hear it is now working for you. Come back to the community anytime if there is anything else you would like to know. 🙂
Hi @Rudihorvath
I was just thinking about your post, thank you so much for sharing this helpful piece of information with the Community.
Because I loved your answer, I'd love to send you out for a brilliant meal on us!
I am going to send you a private message here to get some details, so I can send it out to you.
Many thanks,
Richard
by Alicebw Investigator
Is this under APN management?
is so what is the carrier name to be?
PDP type. Is it. IPv4. Or IPv6. Or  IPv4&v6
APN type. Is it Static or dynamic
EE Employee
Hi @Alicebw and welcome to the community.
So I can try and assist, are you using your TP-Link overseas?
Is there any settings in the device already?
Many thanks,
Lee
I am using a TP LINK 4GLTE. I live in Guernsey so cannot take advantage of the new roaming deals with phones and wifi.
We travel through France to Spain over a few days, so bought the above and was advised to use EE as it was the best provider. It's all works perfecting in the UK for us, but as soon as we landed on the continent we lost connection. Contacted EE who told me we have been sold the wrong package so she updated it to the Europe roaming one. But the TP Link device will not pick it up, if I put the card into my phone it works and we are able to use the personal hotspot to connect other phones and iPads. But I need the TP link mifi to work. The machine is on roaming.
Sorry bit of a long drawn out reply, but hope it helps.
Regards,
Alice
[MOD EDIT:  Removed personal details as this is a public forum]
EE Employee
Hi @Alicebw
The APN details should be:
Name - EE Internet
APN - everywhere
Username - eesecure
Password - secure
Please use IPv4 and let me know how you get on.
Many thanks,
Lee
