by melrose
Cannot make calls or send text from abroad - Error 10
I've been in Spain for a week, and cannot make calls or send text messages. When I try I get an Error 10 message. The same happened when I was in France in May. I can receive both calls and texts. I have tried changing the international prefix to all of the following: +44, 0044 and also no prefix. Nothing works.
Re: Cannot make calls or send text from abroad - Error 10
Hi @melrose
Log into your online account and then menu - Manage device, make sure you have activated roaming and international calls.
Or
From the MyEE app current usage - controls, activate use phone abroad and make international and premium calls
Hi there @melrose
Thanks for coming here 🙂
If everything that @Northerner mentioned is all already set up, or if it still isn't working after, please try manually selecting a different available network:
  • iPhone > Settings > Mobile Data > Network Selection > Turn off Automatic
  • Android > Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows > Settings > Mobile Network > Network Selection > Tap on start manual search
Hope you are all up and running now and having a great time in Spain 🙂
by melrose
Thanks all, but none of the suggestions have worked for me.
Hello there @melrose
Thanks for trying 🙂
I have sent you a private message on here for some details.
