by ninja2
Cannot connect to network in Algeria
HI. I am in Algieria at the moment. My account is set to roam and does so in Europe with no problems. Here I am not getting a network at all.
I have tried to connect manually but get the message that it has failed to connect. I have rebooted multiple times and I have set the connection to 3g. The phone is a Nokia Lumia 830.
EE Employee
Re: Cannot connect to network in Algeria
Hi @ninja2 and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
Please also can I get you to try and ring using format of 00447*********
Also, please let me know If you are using an EE personal or business account?
Are you aware of anyone else able to connect/not connect, just so we can rule out a local network problem.
Many thanks,
Lee
by ninja2
Hi Lee,
I have tried to connect manually. Others in my team (though with Vodafone) have connected. I can see the networks when I do a manual search but it will not connect to them when selected. At present it will not connect to any network so cannot dial any number.
I am a personal customer.
Many thanks
EE Employee
Hi @ninja2
As the suggestions have not worked, please pop to the live chat link.
This can be found in your Private Messages.
Our customer service team will be able to assist with your issue.
The link will be active from now till 8pm (UK TIME).
Let me know how you get on.
Many thanks,
Lee
