by Lun
Cannot call from abroad (China), but can surf internet, text
Hi I'm currently in China and has a small business plan, the company has just added many minutes to my phone so this shouldn't be an add on problem - I've checked my balance and there's sufficient minutest / texts / data.
I have perfect connection to 4G by China Unicom and can receive emails browse internet etc. I can also text UK numbers.
UK numbers can also call me, however whenever I try to call a UK or foreign number it directly beeps to disconnect??!! It seems I'm only able to call local Chinese numbers.
This is rather urgent and causing significant inconvenience, is there a way to solve this problem?
thanks
EE Employee
Re: Cannot call from abroad (China), but can surf internet, text
Good Morning @Lun
Thanks for coming to the Community! Smiley Happy
It sounds like it could be an issue with the network you're connected to or a problem with dial assist.
Have you tried doing a manual network selection and connecting to a different network?
Also what device are you using?
Thanks - Karen. Smiley Happy
by Lun
Device is an iPhone 5s.
Connected to China Unicom. Have not tried manually select carrier.
Lun Nie
lnie@bwenergy.com
Blue Water Energy is authorised and regulated by the Financial Conduct Authority under reference number 565160
______________________________________________________________________
This email has been scanned by the Symantec Email Security.cloud service.
For more information please visit http://www.symanteccloud.com
EE Employee
Thanks for getting back to me @Lun
If you go to Settings > Phone > Scroll down to Dial Assist > Make sure this is Toggled On.
Then try making a call to a UK number.
If this still doesn't work go to Settings > Carrier > Do a manual search.
Let me know how it goes!
