by Kjojo89
New Member
Can use Internet in Spain, can't make calls but can revive calls
My phone keeps saying restricted calls so I am unable to make calls or send normal texts but can use Internet and receive  calls in Spain
by Brilliant Contributor
Re: Can use Internet in Spain, can't make calls but can revive calls
How are you dialing the numbers?
It need to be +44(number missing off the 0)
Hi @Kjojo89
Could you try the +44 suggestion by @BrendonH?
Could you also try manually selecting an alternative Spanish network operator?:-
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Please let us know if any of that works.
Chris 🙂
