by Garethroo Investigator
Can’t use travel pack Bali
I have purchased a travel pack for two phones one for me and partner.
am getting text messages from 150 but cannot use data, call or send messages?
sim card was ordered specifically for this and I have 4G connection but can’t seem to get working, roaming is switched on for iPhone but nothing is happening?
Re: Can’t use travel pack Bali
Hi @Garethroo
Are the Sims PAYG? Did you activate them in the UK?
Yes PAYG, didn’t activate them in UK but have had messages and the packs are showing as active on online account...
Hi @Garethroo,
All new EE SIM cards must be activated on the EE network in the UK before they can be used abroad.
Is there no way of doing this whilst abroad?
Sorry @Garethroo, it's not possible to activate your SIM on a roaming network.
Recent solutions
