by Anngardiner
Can't use my phone in Germany. Can't get in touch with ee HELP
Can't use my phone in Germany and can't get any support.
I had my son call we and ask them to call me but they can't.
Situation with builders at home which means I need to call them.
Totally frustrated
by Anngardiner
I am in Germany and call out or send text
I need to get to an online chat to get my roaming switched on
by Ace Contributor
Re: I am in Germany and call out or send text
Hello, @Anngardiner
Please click on this http://bit.ly/2qCiFHM link and enable your  Roaming,
for live chat click here Get in Touch - EE and under -EE you will find live chat option.
live chat will be open at 8:00 am.
i hope it help you to get to go.
Many thanks
Hi @Anngardiner,
Welcome to the EE Community.
Were you able to activate your roaming services using the link @tahirmian kindly posted? (Thanks @tahirmian!)
Re: Can't use my phone in Germany. Can't get in touch with ee HELP
Hi @Anngardiner,
Are you using an EE, Orange or T-Mobile plan?
Does your phone connect to a network in Germany?
What happens if you try to make a call?
