by Patrus1
Can't use make calls and messages abroad but can use my data EE help please?
Im currently on holiday in Poland. On my contract it said I can use my calls, messages and data abroad as normal as I can use it back at home in uk. Well my data works all fine, no signal problem or nothing. When it comes to calls when ever I try to make a call it ends straight away. (I was trying to call my family in UK)I tried calling with out the first digit 0 or with the area code +44 nothing worked the calls were ending straight away.
Re: Can't use make calls and messages abroad but can use my data EE help please?
Hi @ Patrus1
Thanks for coming here.
Can you send texts ok?
What device are you using?
Also can you try and connect to an alternative network?
Speak soon 🙂
