by stefonas Investigator
Can’t text or call outside the UK
Hello,
I can’t seem to text or call anyone when I am out side the UK but in the EU. However I can still use mobile data.
However I did receive a text from EE saying I should be able to text and call at my usual rate.
by Ace Contributor
Re: Can’t text or call outside the UK
Hi @stefonas
Number you want to Call text use that in international format. eg 00447 for UK.
That might help you to go through.
Hi @stefonas,
Welcome to the EE Community.
I'm sorry to hear you are having problems using your phone outside the UK.
What happens when you try to make a call? Do you hear a recorded message?
Hello,
I have tried that but it still doesn’t work
Hello James,
I don’t get a recorded message just a constant beeping. I also can’t message or call people in the same country I am in, Germany.
Christine
Hi @stefonas,
Please can you try following the steps in EE Roaming - What to do if you're having problems abroad and let me know if they help?
