by Vidge
Can’t text call uk from Greece
Hi there, I’m having trouble calling and texting from Greece to UK.
Solution
Re: Can’t text call uk from Greece
Hi @Vidge
I hope you're having a brilliant time in Greece so far.
Once you've followed the instructions that @XRaySpeX posted, if it still isn't working, please try manually selecting a network:
Device type Actions
iPhone Settings > Mobile Data > Network Selection > Turn off Automatic
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Let us know how you're getting on.
If on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
PAYG is auto enabled for roaming. You don't & can't do the above.
Solution
Hi @Vidge
Device type Actions
by Vidge
Thank you Chris!
all sorted
v
