by SiobhaaanAB Investigator
Can't send texts or make calls from France
Hi, I'm currently in France and I can't seem to send texts or make any phone calls... I can receive both.
I have read many 'solutions' online but none have worked for me. I got told to text Roaming to 150 to activate my phone abroad but it won't let me send the text and the next solution was to phone then but I cannot phone!
Any help would be appreciated!!
Thanks!
Solution
Re: Can't send texts or make calls from France
@SiobhaaanAB : If you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium Rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
PAYG is auto enabled for roaming. You don't need to & can't do any of the above.
8 REPLIES 8
Solution
by DylanC
New Member
This doesn't exist in my MyEE app.
When I arrived in France I got a text saying that calling and texting would be normal, but I also cannot make any calls.
@DylanC : Are you on contract or PAYG? PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything.
I got the same text when I arrived but have no worked since. I had to go onto my online account and turn on my calls and texts thing which for some reason was off. Said it could take 24 hours to work so still not able to text or call but will try this again later
@SiobhaaanAB   Now it’s enabled try restarting the device.
Hi there @DylanC
Thanks for coming here.
If you have a pay monthly account, you will find the settings within your My EE account online not the app.
Let me know how you get on 🙂
I've now tried everything possible and still nothing to fix this. Still cannot send or receive texts and I changed my online settings so I could but everything I go back on to check it says it's blocked then I unblock it but still not working! Still cannot send texts or make calls! Help me!!
Hi there @SiobhaaanAB
I have sent you a private message on here, if you could reply to my message we will be able to get this looked into further for you.
Speak soon.
Leanne 🙂
