by alexdavison
Can't send texts from abroad
I'm in the US and can receive messages but can't send them.
Thanks,
Solution
Re: Can't send texts from abroad
Did you activate roaming on your MyEE a/c before you left? Presumably not. Having a roaming allowance does not auto enable it. You may still be able to in your online a/c under Manage Devices. If not, you will need to call EE. Use the landline nos. in my sig.
Solution
by Profile closed
Not applicable
Hello @alexdavison what phone do you have? Try restarting the phone and/or trying a manual network search and selecting another roaming network if possible.
Did you enable roaming on your account before you left? You can check if roaming has been enabled by logging in to MYEE online and navigating to MYEE>manage device. 🙂
by alexdavison
Thanks I had not indeed as I figured because the signal showed up as roaming that I was connected.
Thanks for clearing up! 🙂
You're welcome :)! Glad I could be of assistance.
