by rosswahoo Investigator
Can't send or recive texts abroad
I am in Qatar and can't recieve or send text messages. I was breifly able to when i arrived but not anymore. Calls works fine as does mobile data.
I am a large buisness customer and roaming should automatically be turned on.
The phone is a Blackberry Leap. I've been through the settings but i cant spot anything.
Any help would be appreciated.
Ross
Re: Can't send or recive texts abroad
Hi @rosswahoo,
Welcome to the EE Community.
Have you tried selecting a different network manually?
Just tried this, only two networks available. Vodafone won't work. The other (which I was connected to previously) works but still no text messages.
Ross
Hi @rosswahoo,
Can you try testing with 4G turned off and see if that allows you to send a text?
The plot thickens. Turning off 4g i can send and recieve texts to/from another UK mobile number but i still can't receive texts from international mobiles (Qatar and Dubai numbers).
Ross
Thanks for testing that for me @rosswahoo
I'm not sure why it's only allowing you text UK numbers.
Please get in touch with business support and the technical team will be able to investigate in more detail for you.
