by clare_h_ee Investigator
Can't send a text from Mongolia
I am in Mongolia on holiday, and although I can receive texts, I cannot send them. I have enough credit, and am connected to a network.
12 REPLIES 12
Re: Can't send a text from Mongolia
Can you make & receive calls?
Receive, yes - haven't made any (and would prefer not to test it as the costs are so high!)
EE Employee
Hi @clare_h_ee
What phone are you using?
Is the number you're sending the text to in +44 formatting?
Have you tried rebooting your phone?
Thanks - Karen. Smiley Happy
It's an LG K4. The number is in +44 format, and I have tried rebooting.
EE Employee
Thanks for getting back to me @clare_h_ee
It sounds like your International bar may still be active.
If you go to Phone > Menu > Call Settings > Call Barring > is there an option for outgoing whilst abroad?
Are you a pay as you go customer?
Hi Karen, yes, I'm PAYG.
Aha! Yes, there is a call barring section. Under "all outgoing" it is on, and the outgoing international section is greyed out. I just pressed on the "all outgoing" option, and it prompted me for a password, but I don't think I have one.
EE Employee
Thought that's what it might be!
The default code should be 0000.
Give this a go and let me know how it goes @clare_h_ee
Thanks, Karen! Unfortunately that's not working for me, when I enter 0000 I get the message "unexpected response from network".
Try 1111.
EE Employee
Thanks for trying @clare_h_ee
If the code @XRaySpeX has given doesn't work either you would need to speak to Customer Services.
They would be able to check for any bars on your account.
Really sorry I couldn't help further on the community!
Thanks both for helping, unfortunately neither code works.
Any tips on how to get in touch with customer service - the webpage only lists numbers to call, and as we've established on this thread, I can't use my phone! Is there a webchat function?
Open up the "+EE" on Get in touch .
