by Itsrickysmith Investigator
Can’t receive or make calls/texts in Germany
my Dad recently gave me his old phone it is EE. So I got a new SIM to put in it, topped it up and it isn’t working. Every call I make it says ‘calls to this number are barred’ or gives the engaged noise before cutting out. I’m in Germany and need to make calls/texts back home. PLEASE HELP!!
Solution
Re: Can’t receive or make calls/texts in Germany
Did you use & activate the new PAYG SIM before leaving UK? It has to be activated on EE's home UK network.
Solution
No I never... I take it that’s the problem? Is there anyway around it? I still get texts from EE though 🤔
That is the problem. You need to be in UK to activate it.
Is there anyway around this?
Hi @Itsrickysmith
No,
EE Sims are designed for the UK network, with roaming as a benefit. Sims need to be activated and used in the UK.
You will need to buy a German PAYG SIM.
