by Cobblers123
New Member
Can't receive calls or text abroad
Re: Can't receive calls or text abroad
@Cobblers123 : Can you make calls & texts & use data?
If on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your My EE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
