by 4dman Investigator
Can’t make or receive calls in USA. Can’t text EE to initiate anything.
Can’t make or receive calls in the USA. Can’t text EE to initiate anything. How do I activate my phone?
EE Employee
Re: Can’t make or receive calls in USA. Can’t text EE to initiate anything.
Hi @4dman and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
Hasn’t worked sorry
Sent from my iPhone
EE Employee
Hi @4dman
Have you used your phone abroad previously?
Many thanks,
Lee
It’s all sorted now thanks Lee. My daughter got in touch with EE for me back in the UK. Thanks for your help
Sent from my iPhone
EE Employee
Brilliant @4dman
I'm glad you are now sorted.
Cheers,
Lee
