by Satishbabu74
Can’t make international calls when In Europe
Solution
Re: Can’t make international calls when In Europe
@Satishbabu74 : If on contract, did you activate roaming on your EE a/c before you left UK?
Try logging into your My EE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
Solution
by Satishbabu74
Thanks for the reply
yes I had Roaming ‘on’ on my phone settings
i figured out based on some online suggestion that...by restarting  the phone: it works
a simple tip apart from checking settings was probably the above
So when in flight just after landing try to put the phone competly off and on instead off in flight mode .
Welcome to the community, @Satishbabu74.
I'm glad it's now working for you. Enjoy the rest of your trip.
Chris 🙂
by Najat
I can’t make call from abroad
I tried to login on my account and I can’t find the dedicated option to activate the roaming calls
can you help?
@Najat : Where are you? Are you on PAYG?
