by Stephanie7
Can't make calls whilst in Tenerife
I have an EE pay monthly contract and cannot make calls whilst in Tenerife. I can send texts and use the WiFi bit no calls at all
Re: Can't make calls whilst in Tenerife
If on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your My EE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
Hi @Stephanie7.
Let us know if you manage to activate roaming and premium rate calls in your My EE Account online.
Are you using the correct dial code?
Jon
by Stephanie7
The problem rectified itself. After texting 150 to roaming and waiting a few hours if began to work. Thanks Steph
That's great @Stephanie7.
Thanks for letting us know, enjoy the rest of your time in Tenerife 🙂
Jon
