by Hodgy28569
Can't make calls or texts in Greece it is saying barred
Can't make calls or texts from Greece it says. Phones barred so I unblocked it and it said would take 24hrs so I left it and when I checked it was back to blocked.
Re: Can't make calls or texts in Greece it is saying barred
@Hodgy28569 : If on contract, did you activate roaming on your EE a/c before you left UK?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your My EE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
