by James1940
Can't make calls or texts abroad
I am currently away and had this proplem before and never been sorted so wondering if this might help? I am abroad and I can receive text messages and use data but I am unable to make calls or send them! Its not great when I am traveling in a group and need to contact them. Hope someone can help!
Solution
Re: Can't make calls or texts abroad
@James1940   login to your EE online account and enable call abroad and premium rate numbers then restart the device.  You can do this also via the my EE app under controls
Solution
Good Morning @James1940
Have you been able to follow the advice from @Chris_B?
Are you now able to make calls and texts?
Speak soon,
Katie 🙂
