by jasmine3
New Member
Can’t make calls or send texts in Spain and Amsterdam
Currently in Amsterdam, can use data but can’t send texts and when I try to call get the message ‘call is not allowed.’
EE Employee
Re: Can’t make calls or send texts in Spain and Amsterdam
Hi @jasmine3 and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Android: Open the Settings menu >Tap More > Mobile Networks > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
