by crillya
Can't make calls or SMS in USA - error 10 (probably international bar)
Hi there!
I've just landed in the US and can't seem to make texts or calls - I'm getting ee error 10.
I checked the other threads and followed all the advice:
Turned on n off, turned off 4g, and checked on myee that roaming was turned on (it was by default)
I think I've got an international bar on - would you be able to help turn it off?
Thanks!
Solution
Re: Can't make calls or SMS in USA - error 10 (probably international bar)
Hi @crillya
Did you also activate international calls (menu - manage your device) as this will also need to be activated in addition to roaming.
Are you on a Max plan? If not then your rates and add ons can be found on EE roaming page.
Solution
Hi @crillya
Good Morning @crillya.
Welcome to the community 🙂
Great advice from @Northerner, you can activate international calls in your MyEE Account.
Let us know how you get on, I hope you have a great time in the USA!
Jon
by crillya
Thanks!
I completely missed the international and premium calls switch - thanks @Northerner 🙂
Cheers!
Thanks for letting us know @crillya!
I'm glad you got the help you needed in the community 🙂
Feel free to come back to the community any time.
Jon
Recent solutions
