by Tckeen
Can't make calls from greece
Hi. I'm in Greece and can't make calls. Data roaming is working but can't make any out going calls or texts.
EE Community Team
Solution
Re: Can't make calls from greece
Hi @Tckeen,
Welcome to the community 🙂
I hope you having a brilliant time in Greece!
Have you been able to receive any calls or texts since you arrived?
If you have a pay monthly account, your international bar may still be active.
You can check this by logging into your My EE account online and go to Menu > Manage Device > Call abroad and Premium rate calls > This will show as ticked if you're set up for making calls when abroad.
Alex 🙂
EE Community Team
Solution
Hi @Tckeen,
Alex 🙂
by Tckeen
Thanks. Sorted now. Turned out to be a premium call Barr that was the issue. Thanks
Thanks for the update @Tckeen
Enjoy the rest of your trip. 🙂
Recent solutions
