Highlighted
by Investigator
Can't make calls from abroad
I've just arrived in Tenerife. My EE plan allows for free calls and texts, and I've received a text confirming this. However I can't make any calls! When I try I get a message from Orange information that "calls to this number are restricted. To gain access or for more information call free phone 470" I can't even call this number as I get the same message!!
20 REPLIES 20
Highlighted
Re: Can't make calls from abroad
@J1mcm: Can you send texts or use data?
Highlighted
by Investigator
Hi there, yes I've just tried sending a text which was received okay. I'm not using data as I'm not paying for extra data
Highlighted
International calls are being barred. Either tick International Calling in your MyEE if it will allow you or else you'll need to call EE.
Highlighted
by Investigator
But I can't call EE because of this issue!!! So does this mean I am basically 'stuffed'?!
Highlighted
Use another phone or try the Freephone no. in my sig over Skype.
Highlighted
Morning @J1mcm
Thanks for coming here.
Can you receive calls and texts?
Speak soon, Leanne.
Highlighted
by Investigator
Hello, I also can't make calls abroad. I can't send texts either but my data is working I have tried a manual network search but i'm only getting the same network.
I am in switzerland.
Some helo would be appreciated
Highlighted
Hello @Ejbej
Are you able to receive calls and texts?
Do you have a pay monthly account?
Speak soon, Leanne 🙂
Highlighted
by Investigator
Hi
I am recieving calls and texts but i can't make any.
I am on a monthly contract.
Highlighted
Thanks @Ejbej
We will see what we can do to help you get up and running.
To do this, I have sent you a private message to get some details.
Speak soon. Leanne 🙂
Highlighted
by Investigator
Ok great thanks.
Highlighted
Hi @Ejbej
If you can reply to my private message with your details when you get a moment 🙂
Thanks, Leanne.
Highlighted
by Investigator
I’m having the same issue.  I can’t receive calls or text.
please help me as soon as possible.
thanks
Highlighted
Hi @Wm994,
Are you using a pay as you go or pay monthly plan?
If pay monthly, have you activated roaming in My EE?
You can find your roaming settings by selecting Manage device from the menu.
Highlighted
by Investigator
im using the pay as you go.
thanks
Highlighted
Hi @Wm994,
Are you a new pay as you go customer?
Was your phone working in the UK?
Highlighted
by Investigator
Yes, I’m a new customer.
I think the issue is that I was supposed to make a call in the uk to register in the network, but I probably didn’t do that correctly.
Now, I’m in Spain...
Highlighted
That's right @Wm994
New SIM cards can only be activated on the home network in the UK.
Highlighted
by Investigator
Ok, so is there anything you can do to get it activated?
What can I do here to get it working?
thanks
Recent solutions
