by Mamajacks7
Can’t make calls from Spain
Why can’t I make calls from Spain even though I received a text saying that I could?
Re: Can’t make calls from Spain
Hi @Mamajacks7,
Welcome to the EE Community.
Can you receive calls?
Do you hear a recorded message when trying to make a call?
by Grille52
Re: Can’t make calls from Portugal
I can’t send sms or make calls from Portugal to uk   Have contract and it’s a personal phone
please help !
by Skilled Contributor
Skilled Contributor
Log in to my EE and remove any calls bars of any type, and make sure roaming is also activated. Log out.
Reboot phone.
If if that doesn’t work, switch off automatic and manual select a network and reboot each manual network selection and try it.
Virgin mobile customers have been having the same issues roaming - if none of that works EE will need to intervene and reset everything at their end.
*Easiest way to find info is*
EE HELP SEARCH https://ee.co.uk/help/help-new
Phone +447953 966 250
Live Chat/Complaints https://ee.co.uk/help/help-new/make-a-complaint
Complaints Code of Practice https://ee.co.uk/help/help-new/safety-and-security/protecting-your-information/complaints-code-of-practice
EE Employee
Hi and welcome to the community @Grille52
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Android: Open the Settings menu >Tap More > Mobile Networks > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
