by Tracey1960
Can’t make calls abroad in USA with roam further add on
by Ace Contributor
Solution
Re: Can’t make calls abroad in USA with roam further add on
Is data working ok though?
Have you got a call spend set? Some have reported having to remove it before roam further works.
Hi @Tracey1960
Is roaming activated on your account?
Try logging into your online account, then menu - manage your device, then tick roaming and international calls.
Hi @Tracey1960.
Welcome to the community.
Let us know if both roaming and premium rate calls are active in your My EE Account as @Northerner suggested.
Do you get an error message or error tone when you try to make a call?
Jon
by Tracey1960
Roaming is on and 4g active but get message saying the service you are trying to use is either restricted or is unavailable - have turned phone on/off but we was supposed to have set all this up for me correctly. Thanks
by Ace Contributor
Solution
Thanks @Tracey1960.
Are you using the correct dial code too?
Jon
