by Emmemarcu2
New Member
Can’t make calls abroad and no one can call me either?
Re: Can’t make calls abroad and no one can call me either?
Hi @Emmemarcu2
Log into your online account and then menu - Manage device, make sure you have activated roaming and international calls.
Or
From the MyEE app current usage - controls, activate use phone abroad and make international and premium calls
Hello there @Emmemarcu2
Thanks for posting on the community 🙂
If everything that @Northerner mentioned is all already set up, or if it still isn't working after, please try manually selecting a different available network:
  • iPhone > Settings > Mobile Data > Network Selection > Turn off Automatic
  • Android > Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows > Settings > Mobile Network > Network Selection > tap on start manual search
Hope you are all up and running now and having a great time 🙂
