by Grangerbrigit
Can’t get network service in Tenerife
Re: Can’t get network service in Tenerife
@Grangerbrigit  Login to your online account and enable roaming, you’ll also need to enable call abroad and premium rate numbers, then restart the device.
Hi @Grangerbrigit.
Let us know if you manage to get a signal after following @Chris_B's advice and activation roaming in your My EE Account.
If it's already active, could you try manually searching for another network?
Jon
by Grangerbrigit
Thanks will try
Regards
Brigit
Let us know how you get on @Grangerbrigit
Leanne 🙂
