by MWB Investigator
Can’t get any service in Spain please help roaming is turned on
by MWB Investigator
Roaming
I need help with getting service in spain
Re: Roaming
@MWB: Did you activate roaming on your MyEE a/c before you left? Presumably not. Having a roaming allowance does not auto enable it. You may still be able to in your online a/c under Manage Devices. If not, you will need to call EE. Use the landline nos. in my sig.
Re: Can’t get any service in Spain please help roaming is turned on
EE Employee
Hi @MWB and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
Do a manual network search & choose any local network other than Orange ES.
