by Magictorch69
Can’t dial out or text
I have roaming turned on & activated but can’t send messages or make calls?? I can only receive them 😣😩 urgently need to fix this as I need to make calls for work!! Help please!
Re: Can’t dial out or text
@Magictorch69  Just to check your are putting 44 instead of the 0 at the start of the number?
by Magictorch69
Yes & dial assist is on - same problem with both numbers on the same contract
Hi @Magictorch69
Welcome to the community, we'll do our best to help you get connected.
Which country are you in at the moment?
Please try the steps below:-
Try re-booting your device
Try turning 4G off in ‘settings’
Perform a manual network search:-
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Please let me know if any of that works.
