by WillDav99 Investigator
Can't access data neworks in EU on Pay As You Go
Hello, I am unable to access data networks while roaming in the EU on a Pay As You Go SIM with the Promotional Everything Pack. Calls and texts are working fine.
I have ensured Data Roaming is switched on on my Sony Experia Z3, I have switched off the 4g, and I have searched different local networks, but I can't access any data networks to get online.
This is currently a problem in Slovenia, but was also a problem in France earlier this year.
Can you help?
Thank you
Solution
Re: Can't access data neworks in EU on Pay As You Go
Thanks Christopher. This has been solved. The problem was my handset is locked to the 'euinternet' APN. The solution was to enter the EE APN settings in the euinternet APN (but leave the APN name as 'euinternet'). Cheers, Will
6 REPLIES 6
Do you have any data allowance left in your current pack? Do you in fact have a pack? You can't use data w/out a pack.
What does texting AL to 150 report?
Thank you. As I wrote, I have the Promotional VIP Everything Pack. There is 16GB of data left for a pack that ends in 22 days.
Is anyone able to help with this query?
Hi @WillDav99
Welcome to the community.
Do you have a strong connection/signal bars?
I've sent you a private message to get some more information from you.
Please take a look and get back to me.
Solution
Thanks for the update @WillDav99
Glad you got it sorted.
