by michelleperalta Investigator
Can't access data in Switzerland
Hi there,
I arrived in Switzerland yesterday and have not been successful in accessing my data. Data roaming has been turned on.
For some reason in my phone settings I'm being told I've exceeded my data by about 3GB but when I look at my EE app it tells me I've still got 7.5GB left. The latter makes more sense as I haven't been excessive with my data usage back in the UK.
I tried sending a ROAMING text to 150 but it won't send, so at this point I've got no idea what else I can do.
  • I've got a Huawei P20 which I've had since December if that helps.
Thank you,
Michelle
Solution
Re: Can't access data in Switzerland
@michelleperalta   did you enable roaming on your account?? If not you can log into your EE online account and enable roaming from there you also need to enable call abroad and premium rate numbers then restart the device
Solution
Hi @Chris_B
Data roaming is enabled. I've just tried enabling the premium calls but I get a message saying the app isn't working and to try again later. 😞
Update: it's working. Thanks for your help, @Chris_B! 🙂
Hi @michelleperalta
Thanks for coming back and letting us know 🙂
Have a great time.
