by Chaperz85
New Member
Can i use my data in the eu
by Profile closed
Not applicable
Solution
Re: Can i use my data in the eu
Hello @Chaperz85 it depends what plan you have. Only EE PAYM EXTRA or MAX plans currently include EU data roaming however, from 15th June 2017 all customers PAYG & PAYM will be able to use their UK allowances within the EU & EEA:
https://community.ee.co.uk/t5/Roaming/Free-EU-roaming-Who-s-covered-and-what-s-included/td-p/559046
http://shop.ee.co.uk/international/travelling-abroad
You can check what it would would cost to use your phone abroad and whether you need a data roaming add on or not before then by using the roaming tool contained in this link:
http://explore.ee.co.uk/roaming
by Profile closed
Not applicable
Solution
Hello there @Chaperz85
Great advice @Profile closed thanks very much.
I would also contact customer service before you go to the EU to make sure your account is all set up for Roaming.
Have a lovely time 🙂
