Highlighted
Can i use my data i Spain?
Highlighted
by Brilliant Contributor
Solution
Re: Can i use my data i Spain?
@Emitas Yes you can use any U.K. allowances in Spain subject to a fair usage of 15gb per month on Data.
Just text roaming to 150 before you go to make sure your all set up
Highlighted
Solution
Recent solutions
