by Emiliaoukaci50_
New Member
Can i use data and calls and texts in Turkey
Can I use data and calls and texts in Turkey
Re: Can i use data and calls and texts in Turkey
@Emiliaoukaci50_   Unfortunately you can not use your allowances in Turkey.   Text RO TURKEY to see what your options are.
If you still wish to use your device you need to text ROAMING to 150 before you leave the UK, you can do this now if you wish.
Hi @Emiliaoukaci50_.
Welcome to the community.
As @Chris_B has mentioned you can't us your inclusive allowances in Turkey, but have a look at our Roaming Page to see the costs and add-ons available.
Jon
