by Evedenwer12
New Member
Can i upgrade my data usage asap
I'm stuck at a train station and have more hours to travel and running out of data please can I upgrade my monthly allowance asap rather than buying an add on
Re: Can i upgrade my data usage asap
@Evedenwer12  You’ll need to call customer services to that I’m afraid and customer services is now closed.   Even if you was to upgrade your tariff allowance it wouldn’t start until your next billing cycle.
Hi @Evedenwer12,
Thanks for visiting the EE Community.
That's great advice from @Chris_B, our customer service team will be happy to help you change your plan.
