by DrWu
Can anyone tell me why my phone is not working in The Bahamas?
My old Nokia handset is not working in the Bahamas. It has always worked abroad, outside the EU as well as within. It didn't work whilst I was in transit in Miami either so maybe more than just a Bahamas thing. I'm on an old Sim only contract with Orange.
EE Employee
Solution
Re: Can anyone tell me why my phone is not working in The Bahamas?
Hi @DrWu
I've just had a quick check and can see that the device is not tri-band and will not work in the USA or Bahamas.
I would have a word with your hotel reception just in case they can loan you a phone as I know some hotels do offer that service.
Many thanks,
Lee
8 REPLIES 8
by Ace Contributor
Hello @DrWu what model Nokia do you have?
by DrWu
I can't see a model number written on it. It was a cheap PAYG handset that I put my existing sim in. Not a smart phone. Only ever used it for calls and texts.
EE Employee
Hi and welcome to the community @DrWu
So I can try and help please type in *#0000# this should present you with the model number.
It could be that your device is not triband.
Do let us know.
Many thanks,
Lee
by DrWu
Maybe you're right with the triband thing. It's worked in Aus, NZ, Malaysia, India before but haven't been to USA with it before. My phone is so cheap and basic that it doesn't show model number when typing #0000#. Will have a look online and see if I can find model number.
by DrWu
It looks like the Nokia 108.
EE Employee
Solution
Hi @DrWu
Many thanks,
Lee
by DrWu
Thanks for your help Lee. Much appreciated.
EE Employee
No problems @DrWu
Do enjoy your time in the Bahamas.
Many thanks,
Lee
