by Mayp
New Member
Can I use this sim and data in Antalya Turkey?
Can I use this sim and data in the United States?
Re: Can I use this sim and data in Antalya Turkey?
Hi @Mayp
Which is it Turkey or the US?
Both aren't in the EU so you can (subject to you activating roaming) roam in both, but the cost is expensive. You can buy add-ons which can help with the cost.
If you have an EE max plan you can roam in the USA as at home (limited to 15GB of data) if not the charges are below.
Turkey roaming
USA roaming
@Mayp   Where do you want to use it ?    If you have a max plan you can use it in the USA but Max plans do not cover turkey and neither do standard contract tariffs as Turkey is not in the EU
If you are not on an EE Max Plan, which includes US roaming, you could buy the Roam Further Pass for £10 pm. Otherwise the charges will be as set out in https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/usa .
