by julietbailey
Can I use my plan in Lanzarote
can I use my plan in Lanzarote ie minutes and data
Solution
Re: Can I use my plan in Lanzarote
@julietbailey   Yes you can.  Just text. ROAMING to 150 to make sure roaming is enabled.  And login to your EE online account and activate  call abroad and premium rate numbers.
Solution
Good Morning and welcome to the community @julietbailey 🙂
That's great advice from @Chris_B!
You can use your minutes, texts, and data as normal in Lanzarote.
I hope you have a great time away 🙂
Jon
