by Chloerooney
New Member
Can I use my phone when I go to Bulgaria
Solution
Re: Can I use my phone when I go to Bulgaria
Yes, it is part of EU. You may use your usual allowances there with up to 15 GB data per billing month if you have more.
If you are on contract, remember to text ROAMING to 150 before you leave to check roaming is enabled on your account.
Solution
