by LorraineMyles
Can I use my phone internally
I am going to Canada on holiday and I need to know whether I will be able to use my while over there.
Hope you you can help
thanks, Lorraine
Solution
Re: Can I use my phone internally
@LorraineMyles : Roaming charges there can be found in https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/canada .
@David : It's now called ROAM FURTHER & costs £10 / month.
by Ace Contributor
Hi @LorraineMyles
Welcome to the EE Community,
If your on a EE max plan your inclusive allowance will be useable while in Canada if your on a EE essential plan you will need to purchase the go further add on which will cost £10 a month you can add it by texting GO FURTHER to 150 and to remove it text STOP GO FURTHER to 150.
TEXT ROAMING to 150 before you leave to ensure roaming is enabled on your account.
Solution
