by Katie83
Can I use my phone in zante
Can I use my phone for call and texting in zante
by Ace Contributor
Solution
Re: Can I use my phone in zante
Hi @Katie83
Welcome to the EE Community,
Yes you can use your phone as normal while in Zante.
Text roaming to 150 before you go to make sure it's enabled.
Thanks,
David.
by Katie83
Thanks David
by Ace Contributor
Solution
Hi @Katie83
Thanks,
David.
EE Community Team
Hi @Katie83,
Thanks for coming here 🙂
You can check what is included in your plan depending on if you are on pay monthly or pay as you go  whilst in Greece.
You can also check you have your phone and account set up to travel by checking out our Roaming article here on the community.
Have a great trip!
Alex 🙂
