by Ganoomfy
Can I use my phone in spain
Can I use my phone in Spain at no extra cost to my contract?
by Brilliant Contributor
Solution
Re: Can I use my phone in spain
Hi @Ganoomfy Yes you can. Text Roaming to 150 before you go to make sure your all set up
Solution
by 15183
New Member
Hi I texted roaming to 150 do you get a confirmation that you phone is registered John
Hello there @15183
Thanks for coming here.
Did you get a reply when you text ROAMING to 150?
You can also activate roaming within your My EE account online.
Go to Menu > > Manage Device > Roaming Abroad >This will show as ticked if roaming is activated.
You will also need Call Abroad and Premium Rate Calls ticked to make calls and send texts.
Where are you travelling to?
Leanne 🙂
