by Jenny08
Can I use my phone in Turkey for free
Does anyone know if I can use my phone in Turkey for free??
Solution
Re: Can I use my phone in Turkey for free
Hi @Jenny08
Unfortunately not. Turkey isn't within your EU roaming entitlement.
You will need to but an add on.
Solution
Hi @Jenny08
by Jenny08
Ok thanks,
Hello there @Jenny08
I can see you have had your question answered by @Northerner
Just to add, if you're with us on a pay monthly account text ROAMING to 150 before you go to make sure you are all set up to use your phone abroad.
Hope you have an amazing time 🙂
by Scholarly Contributor
Yes it's a massive shame you cannot Roam for Free like you can with Vodafone in Turkey.
