by Shiaq
Can I use my phone in Pakistan?
Hi. I'm going to Pakistan for 3 weeks on the 12th of October. Can I use my allowance of minutes and data in Pakistan?
Solution
Re: Can I use my phone in Pakistan?
No, your UK allowances are only valid in the EU + possibly 5 other countries that does not include Pakistan if you are on a recent EE Max Plan. You will need to buy add-ons. See http://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/pakista... for prices.
Before you go text ROAMING to 150 to check you have roaming enabled on your a/c.
Solution
Hi @Shiaq
Welcome to the community. 🙂
@XRaySpeX is spot on above.
Find out more information on what you need to do before you travel abroad >
Have a brilliant trip. 😄
