by PeterDevlin62
New Member
Can I use my phone in Mexico
Solution
Re: Can I use my phone in Mexico
Hi @PeterDevlin62
Yes you can but depending on the tariff you have you may have free roaming. If you have one of the new swappable tariffs with The roam further swappable, or an EE max plan taken out after 10/05/17 then you can roam as at home (15GB maximum data fair use limit)
Alternatively roaming costs for Mexico cam be found here;
https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/mexico
Just remember to text ROAMING to 150 to ensure your service is activated.
Solution
Hi @PeterDevlin62
